I have the following systemd service to run my flask app:
[Unit]
Description=My Flask server
After=network.target
[Service]
User=ubuntu
ExecStart=/home/ubuntu/my-server/script.py
WorkingDirectory=/home/ubuntu/my-server/
Restart=on-failure
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
However, when I run
systemctl start my-server.service
I get the following status
my-server.service - My Flask server
   Loaded: loaded (/etc/systemd/system/my-server.service; enabled; vendor preset: enabled)
   Active: active (exited) (Result: exit-code) since Wed 2017-06-21 22:24:18 UTC; 8min ago
 Main PID: 8407
(code=exited, status=203/EXEC)
How do I prevent the Flask server from exiting? When I run the script directly with
it works fine. But if I run it with systemd, the server exits immediately.
k26dr
  • 191
Not sure if this helps but this is the service file that I use to control a flask application for a personal project. I think by default, systemd will run a script with a /bin/sh shell with no personalizations. You might want to try switching to a /bin/sh shell and running your command. There may be an environment variable missing.
Unit file from link:
[Unit]
Description=Persistent Transactions API
After=syslog.target network.target electrum.service
[Service]
User=percy
Group=percy
ExecStart=/bin/bash -c "source /opt/persist_transaction/bin/activate ; /opt/persist_transaction/api.py -c /opt/persist_transaction/config.ini"
Restart=always
[Install]
Fixed my own problem. I had to change the file owner to match the systemd script and then make it executable:
chown ubuntu /home/ubuntu/my-server/script.py
chmod +x /home/ubuntu/my-server/script.py
k26dr
  • 191
