I'm having trouble getting my external monitor working with my Asus R556LA which has the Intel HD5500 integrated graphics on Ubuntu 16.04. The issue started appearing a few days ago, and before that period I had no issues whatsoever with using the monitor. When I connect the monitor with HDMI, Ubuntu does not recognize it in the "Display" section and the monitor itself keeps switching from analog to HDMI output.
Here's the output I'm getting by running lshw -c video:
sudo lshw -c video
*-display
description: VGA compatible controller
product: Broadwell-U Integrated Graphics
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:48 memory:f6000000-f6ffffff memory:e0000000-efffffff ioport:f000(size=64) memory:c0000-dffff
The kernel version I'm running is 4.8.0-56-generic. I've found that the Intel integrated graphics are part of the kernel which leads me to believe that a kernel update might've wrecked the drivers for me. I've tested the monitor on another setup to rule out that the monitor was broken.
EDIT: For some reason it does seem to be working when I connect it with a VGA cable. I tried other HDMI cables to see if it was the cable but no luck there either. I'd like to get the HDMI cable working as VGA only allows resolutions up to 1024p while HDMI can use a higher resolution (1080p in my case).
EDIT2: Here's the output of xrandr with VGA plugged in:
Screen 0: minimum 320 x 200, current 2390 x 768, maximum 8192 x 8192
eDP-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1366x768 60.03*+
1360x768 59.80 59.96
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 60.00
960x540 59.99
800x600 60.00 60.32 56.25
840x525 60.01 59.88
800x512 60.17
700x525 59.98
640x512 60.02
720x450 59.89
640x480 60.00 59.94
680x384 59.80 59.96
576x432 60.06
512x384 60.00
400x300 60.32 56.34
320x240 60.05
DP-1 connected 1024x768+1366+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
HDMI-1 disconnected (normal left inverted right x axis y axis)
And here it is with HDMI plugged in:
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192
1366x768 60.03*+
960x720 60.00
928x696 60.05
896x672 60.01
960x600 60.00
960x540 59.99
840x525 60.01 59.88
800x512 60.17
700x525 59.98
640x512 60.02
720x450 59.89
640x480 60.00 59.94
680x384 59.80 59.96
576x432 60.06
512x384 60.00
400x300 60.32 56.34
320x240 60.05
DP-1 disconnected (normal left inverted right x axis y axis)
