I am in a situation where package click is broken. I have tried many things, but did not manage to fix it.
$ sudo apt dist-upgrade
Reading package lists... Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these.
The following packages have unmet dependencies.
click : Depends: python3-click-package (= 0.4.43+16.04.20160203-0ubuntu2) but 0.4.43+16.04.20170613-0ubuntu1 is installed
E: Unmet dependencies. Try using -f.
Obvioulsy sudo apt-get -f install does not fix it. Nor trying to remove python3-click-package.
Any help welcomed.
$ apt-cache policy click python3-click-package
click:
Installed: 0.4.43+16.04.20160203-0ubuntu2
Candidate: 0.4.43+16.04.20170613-0ubuntu1
Version table:
0.4.43+16.04.20170613-0ubuntu1 500
500 http://gb.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
*** 0.4.43+16.04.20160203-0ubuntu2 500
500 http://gb.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
100 /var/lib/dpkg/status
python3-click-package:
Installed: 0.4.43+16.04.20170613-0ubuntu1
Version table:
*** 0.4.43+16.04.20170613-0ubuntu1 500
I can not even remove the package:
$sudo apt-get -f purge click
The following packages will be REMOVED
click*
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
2 not fully installed or removed.
After this operation, 88.1 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 590369 files and directories currently installed.)
Removing click (0.4.43+16.04.20160203-0ubuntu2) ...
Traceback (most recent call last):
File "/usr/bin/click", line 55, in <module>
from click import commands
ImportError: cannot import name 'commands'
dpkg: error processing package click (--purge):
subprocess installed pre-removal script returned error exit status 1
Job for click-system-hooks.service failed because the control process exited with error code. See "systemctl status click-system-hooks.service" and "journalctl -xe" for details.
click-system-hooks.service couldn't start.
click
