Despite following the recommended command line for .jar file :
java -jar imker-cli.jar
It doesn't work for me :
me@pc:~/Documents/imker$   java -jar imker-cli.jar
The program 'java' can be found in the following packages:
 * default-jre
 * openjdk-8-jre-headless
 * gcj-4.8-jre-headless
 * gcj-4.9-jre-headless
 * gcj-5-jre-headless
 * gcj-6-jre-headless
 * openjdk-9-jre-headless
Try: sudo apt install <selected package>
What is going on ? What should I do to run this .jar file ?
Hugolpz
  • 221
The error message you got ask you to install java. Run :
sudo apt-get install default-jre
and it should work.
Hugolpz
  • 221
