I'm unable to install a new package via ssh.
sudo apt-get install default-jdk
gives the following error:
You might want to run 'apt-get -f install' to correct these:
 default-jdk : Depends: default-jre (= 2:1.8-56ubuntu2) but it is not going to be installed
               Depends: default-jdk-headless (= 2:1.8-56ubuntu2) but it is not going to be installed
               Depends: openjdk-8-jdk but it is not going to be installed
 linux-image-extra-4.4.0-79-generic : Depends: linux-image-4.4.0-79-generic but it is not going to be installed
 linux-image-generic : Depends: linux-image-4.4.0-79-generic but it is not going to be installed
                       Recommends: thermald but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
When I try the suggested sudo apt-get -f install, there are are more errors displayed:
The following packages were automatically installed and are no longer required:
  linux-headers-4.4.0-31 linux-headers-4.4.0-31-generic linux-headers-4.4.0-43
  linux-headers-4.4.0-43-generic linux-headers-4.4.0-45
  linux-headers-4.4.0-45-generic linux-headers-4.4.0-47
  linux-headers-4.4.0-47-generic linux-headers-4.4.0-51
  linux-headers-4.4.0-51-generic linux-headers-4.4.0-53
  linux-headers-4.4.0-53-generic linux-headers-4.4.0-57
  linux-headers-4.4.0-57-generic linux-headers-4.4.0-59
  linux-headers-4.4.0-59-generic linux-image-4.4.0-31-generic
  linux-image-4.4.0-43-generic linux-image-4.4.0-45-generic
  linux-image-4.4.0-47-generic linux-image-4.4.0-51-generic
  linux-image-4.4.0-53-generic linux-image-4.4.0-57-generic
  linux-image-4.4.0-59-generic linux-image-extra-4.4.0-31-generic
  linux-image-extra-4.4.0-43-generic linux-image-extra-4.4.0-45-generic
  linux-image-extra-4.4.0-47-generic linux-image-extra-4.4.0-51-generic
  linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic
  linux-image-extra-4.4.0-59-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
Suggested packages:
  fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 167 not upgraded.
14 not fully installed or removed.
Need to get 0 B/21.9 MB of archives.
After this operation, 66.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 444493 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-79-generic_4.4.0-79.100_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-79-generic (4.4.0-79.100) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-79-generic_4.4.0-79.100_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-4.4.0-79-generic' to '/boot/vmlinuz-4.4.0-79-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-79-generic /boot/vmlinuz-4.4.0-79-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-79-generic /boot/vmlinuz-4.4.0-79-generic
What could I do to repair the installation ? And what could be the original problem ? Thanks for any suggestion.
Edit: The boot partition must be full df -h gives
Filesystem                           Size  Used Avail Use% Mounted on
udev                                 1.8G     0  1.8G   0% /dev
tmpfs                                370M  5.6M  364M   2% /run
/dev/mapper/server--samuel--vg-root  1.8T  8.9G  1.7T   1% /
tmpfs                                1.9G     0  1.9G   0% /dev/shm
tmpfs                                5.0M     0  5.0M   0% /run/lock
tmpfs                                1.9G     0  1.9G   0% /sys/fs/cgroup
/dev/mapper/pdc_bbfbjjfjce1          472M  470M     0 100% /boot
tmpfs                                370M     0  370M   0% /run/user/1000
Is there something that can be done via ssh or is it necessary to boot on a cd to modify the partitioning ?
You have a lot of kernels which you don't need installed. Those take up space on your boot partition.
Remove the unneeded ones:
sudo apt-get autoremove
Then fix your dependencies:
And then do what you wanted to do originally:
UTF-8
  • 5,910
  • 34
  • 68
