19
I am trying to format a drive using the Ubuntu Disks utility. When I select and try to format the drive I get
Error wiping device.  Command-line wipefs -a "/dev/sdb" exited with non-zero exit status 1: wipefs: error: /dev/sdb: probing initialization failed: Device or resource busy (udisks-error-quary,0)
Nothing I know of us using it and I am doing this from a Live CD boot. What to do?
Steve
  • 323
5 Answers5
29
Use the -f (force) option:
wipefs -af /dev/sdb
fosslinux
  • 3,881
13
Unmount the disk and all the partitions on it:
sudo umount /dev/sdb*
Then retry the wipe.
fosslinux
  • 3,881
Just wanted to add, in my case I had attached 4 drives that were previously in a RAID on that machine. I had never stopped the existing RAID after disconnecting the drives, so I had to:
mdadm --stop /dev/mdX, replacing X with whatever your previous RAID was.
NessDan
  • 181
Use a GParted live CD (or some other distribution containing GParted) to wipe the partition.
fosslinux
  • 3,881
You have to unmount the drive. You can run lsblk to see where the drive is mounted, and then you can umount it, for example, when trying to wipefs on sdc:
lsblk output:
sda           8:0    0 476.9G  0 disk
├─sda1        8:1    0 476.4G  0 part
└─sda2        8:2    0   523M  0 part
sdb           8:16   0 698.6G  0 disk
└─sdb1        8:17   0 698.6G  0 part
sdc           8:32   1  28.9G  0 disk
├─sdc1        8:33   1   748M  0 part /run/media/user/ARCH_202109
└─sdc2        8:34   1    84M  0 part
then I had to run: sudo umount /run/media/user/ARCH_202109
and then, I could wipefs --all /dev/sdc
aurelia
  • 101
