I've recently installed Cuda and, as far as I'm aware, it is working correctly.
which nvcc returns
/usr/local/cuda-8.0/bin/nvcc
running tf.Session() returns
2017-06-16 16:56:24.119619: W
tensorflow/core/platform/cpu_feature_guard.cc:45] The TensorFlow
library wasn't compiled to use SSE4.1 instructions, but these are
available on your machine and could speed up CPU computations.
2017-06-16 16:56:24.119682: W
library wasn't compiled to use SSE4.2 instructions, but these are
2017-06-16 16:56:24.119698: W
library wasn't compiled to use AVX instructions, but these are
2017-06-16 16:56:24.119711: W
library wasn't compiled to use AVX2 instructions, but these are
2017-06-16 16:56:24.119724: W
library wasn't compiled to use FMA instructions, but these are
2017-06-16 16:56:24.249220: E
tensorflow/stream_executor/cuda/cuda_driver.cc:406] failed call to
cuInit: CUDA_ERROR_UNKNOWN
2017-06-16 16:56:24.249294: I
tensorflow/stream_executor/cuda/cuda_diagnostics.cc:145] kernel driver
does not appear to be running on this host: /proc/driver/nvidia/version does not exist
dpkg --get-selections | grep nvidia returns
nvidia-smi, however, returns
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver.
Make sure that the latest NVIDIA driver is installed and running.
and
lspci -v | grep "VGA controller" returns
00:02.0 VGA compatible controller: Intel Corporation Skylake Integrated Graphics (rev 06) (prog-if 00 [VGA controller])
which seems to indicate that the nvidia isn't being used?
Could someone point me in the right direction to getting this sorted?
Thank you very much
EDIT: IMPORTANT
nvidia-settings reported that the NVIDIA driver is not loaded and that it could not find the registry key file
nvidia is known for being buggy with linix. you need the proprietary drivers. the most common nvidia drivers are available in the restricted/non-free repo. istalling the drivers should fix all the nvidia issues.
ravery
  • 6,924
