I have tried all of the solutions I can find on here to fix this.
I have removed and installed various combinations of the libGL.so.1 for 32 bit and I have it now where the GUI for steam will come up but it won't run the whole thing.
I did a clean install after I installed my GTX 1060 the other day. Steam was working just fine before that, so I know it's not my setup. However maybe installing the nvidia drivers before steam was the problem?
Here is the output when I try to run steam:
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
Error: You are missing the following 32-bit libraries, and Steam may not run:
libGL.so.1
Installing breakpad exception handler for appid(steam)/version(1496897923)
Failed to load steamui.so - dlerror(): libGL.so.1: wrong ELF class: ELFCLASS64
[2017-06-16 01:59:01] Startup - updater built Jun 8 2017 04:33:02
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2017-06-16 01:59:01] Checking for update on startup
[2017-06-16 01:59:01] Checking for available updates...
[2017-06-16 01:59:02] Download skipped: /client/steam_client_ubuntu12 version 1496897923, installed version 1496897923
[2017-06-16 01:59:02] Nothing to do
[2017-06-16 01:59:02] Verifying installation...
[2017-06-16 01:59:02] Performing checksum verification of executable files
[2017-06-16 01:59:02] Verification complete
[2017-06-16 01:59:06] Shutdown
All I want to do is get my steam up and running again. I hope someone out there has some ideas.
