I was trying to install qgis..
http://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
So when I ran...
sudo apt-get install qgis python-qgis qgis-plugin-grass
I got the error below...
Reading package lists... Done
Building dependency tree
python-qgis is already the newest version.
qgis-plugin-grass is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up qgis-providers (1:2.18.9+13jessie) ...
/usr/lib/qgis/crssync: error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory
dpkg: error processing package qgis-providers (--configure):
 subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of qgis:
 qgis depends on qgis-providers (= 1:2.18.9+13jessie); however:
  Package qgis-providers is not configured yet.
dpkg: error processing package qgis (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of qgis-plugin-grass:
 qgis-plugin-grass depends on qgis (= 1:2.18.9+13jessie); however:
  Package qgis is not configured yet.
dpkg: error processing package qgis-plugin-grass (--configure):
 qgis-providers
 qgis
 qgis-plugin-grass
sudo dpkg --configure -a
sudo apt-get install -f
 qgis-providers
 qgis
 qgis-plugin-grass
Zanna
  • 72,312
As stated in the error message /usr/lib/qgis/crssync: error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory, you need to install libmysqlclient18.
If you are using Ubuntu 14.04, then sudo apt-get install libmysqlclient18.
If you are using Ubuntu 16.04, then libmysqlclient18 is not available anymore (replaced by libmysqlclient20). You may follow the answer at https://superuser.com/questions/1101426/installing-libmysqlclient18-on-ubuntu-16-04
