I have a script called backup.sh:
#!/bin/bash
sudo zip -r /home/jazuly/backup.zip /var/lib/automysqlbackup/
cd /home/jazuly/backupscript/cp2google/
php cp2google.php /home/jazuly/backup.zip
cd ~
rm -f /home/jazuly/backup.zip
I made it executable:
sudo chmod +x backup.sh
Then I tried to edit cronwith crontab -e.
I add:
# m h dom mon dow command
0 0 * * * /home/jazuly/backup.sh
but when cron sends the backup.zip to my email, I download and open it, and the file is corrupt.
If I run the script manually with:
$ sudo chmod +x backup.sh
$ ./backup.sh
I can open the zip file.
prolificslacker
  • 1,315
  • 17
Jazuly
  • 203
You will need to use the full path in any cron executed script. So, don't do cd ~, give instead cd /home/jazuly
For further debugging, you can also redirect the output of the cron script to a file, with /home/jazuly/backup.sh 1> /home/jazuly/log.txt 2> /home/jazuly/err.txt
So the whole command:
0 0 * * * /bin/bash /home/jazuly/backup.sh 1> /home/jazuly/log.txt 2> /home/jazuly/err.txt
seanlano
  • 3,086
Try to use full paths
#!/bin/bash
/usr/bin/zip -r /home/jazuly/backup.zip /var/lib/automysqlbackup/
/usr/bin/php /home/jazuly/backupscript/cp2google/cp2google.php /home/jazuly/backup.zip
And add /bin/bash in cron
And check permissions for files backup.zip, backupdatabaseterbaru-c771cd4f4fcf.p12
zombic
  • 181
Here are the steps of how I fixed it:
  1. Change Permission & Owner of var/lib/automysqlbackup to 777 & jazuly.jazuly.
  2. Move all the folders & files from backupscript/cp2google/ to home/jazuly.
  3. Use wait for every statement.
  4. My final code:
    #!/bin/bash
    zip -r backup.zip /var/lib/automysqlbackup/
    wait
    php cp2google.php backup.zip
    wait
    rm -f backup.zip
    And my cron:
    to backup every midnight/day.
    I don't think there is a need to write the full path if the .sh file is in the same path with what you want to execute.
Jazuly
  • 203
