I'm getting the following error whenever I try to install a package or update.
ubuntu@ip-172-31-60-64:~$ sudo apt-get update
Err:1 http://archive.ubuntu.com/ubuntu xenial InRelease
Temporary failure resolving 'archive.ubuntu.com'
Err:2 http://security.ubuntu.com/ubuntu xenial-security InRelease
Temporary failure resolving 'security.ubuntu.com'
Err:3 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Err:4 http://archive.ubuntu.com/ubuntu xenial-backports InRelease
Reading package lists... Done
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-backports /InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/InRelease Temporary failure resolving 'security.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
I've seen other answers relating to this problem. But, none of them worked. The instance is running in AWS and the traffic rules are properly set.
Ifconfig output as follows..
ifconfig
eth0 Link encap:Ethernet HWaddr 12:d2:b3:9a:b4:c8
inet addr:172.31.60.64 Bcast:172.31.63.255 Mask:255.255.240.0
inet6 addr: fe80::10d2:b3ff:fe9a:b4c8/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:9001 Metric:1
RX packets:3436 errors:0 dropped:0 overruns:0 frame:0
TX packets:3359 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:277901 (277.9 KB) TX bytes:307892 (307.8 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:480 (480.0 B) TX bytes:480 (480.0 B)
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.8.0.1 P-t-P:10.8.0.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
The nslookup is...
nslookup archive.ubuntu.com
;; connection timed out; no servers could be reached
This question has been marked as duplicate. But, the original question did not resolve my issue.
Contents of /etc/hosts
127.0.0.1 localhost
127.0.1.1 ip-172-31-60-64
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
