So I'm trying to get calcinai/xero-php installed using Composer but am getting this error in specific.
Your requirements could not be resolved to an installable set of packages.
  Problem 1
    - The requested package calcinai/xero-php No version set (parsed as 1.0.0) is satisfiable by calcinai/xero-php[No version set (parsed as 1.0.0)] but these conflict with your requirements or minimum-stability.
Installation failed, reverting ./composer.json to its original content.
I've tried installing both by adding "calcinai/xero-php": "1.5.*" to my require list and by entering composer require calcinai/xero-php in the terminal.
Here is the json file currently:
    "name": "calcinai/xero-php",
    "type": "library",
    "description": "A client implementation of the Xero API, with a cleaner OAuth interface and ORM-like abstraction.",
    "homepage": "https://github.com/calcinai/xero-php",
    "license": "MIT",
    "require": {
        "php": ">=5.5.0",
        "ext-curl": "*",
        "ext-openssl": "*",
    "require-dev": {
        "phpunit/phpunit": "~4.7",
        "fabpot/goutte": "~2.0",
        "twig/twig": "1.16.2"
    "repositories": [
    "autoload": {
        "psr-4": {
            "XeroPHP\\": "src/XeroPHP/"
Any help would be appreciated.
kenorb
  • 10,944
I have solved my problem by adding "version": "1.5.0", after "description" in composer.json.
require: php: >=5.5.0, ext-curl, ext-openssl, calcinai/xero-php: ^1.8
    "type": "library",
    "version": "1.8.6",
    "license": "MIT",
    "require": {
        "php": ">=5.5.0",
        "ext-curl": "*",
        "ext-openssl": "*",
        "calcinai/xero-php": "^1.8"
    "require-dev": {
    "repositories": [
    "autoload": {
        "psr-4": {
karel
  • 122,292
  • 133
  • 301
  • 332
