On Ubuntu 16.04 I added the following line to /etc/apt/source.list:
deb http://downloads.sourceforge.net/project/sonar-pkg/deb binary/
Then I run sudo apt-get update. The following warning shows up:
W: The repository 'http://downloads.sourceforge.net/project/sonar-pkg/deb binary/ Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Is there a way to pass a authentication for the sonar packages to apt?
JJD
  • 882
There is no problem
When you run sudo apt install sonar you will see this message:
Install these packages without verification? [y/N]
Just press y and sonar will be installed :)
Arun
  • 2,011
Have just faced the same problem: Ubuntu 17.10 Artful:
E: The repository 'http://downloads.sourceforge.net/project/sonar-pkg/deb binary/ Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
Temporary solution is to download the Debian package and install it like:
dpkg -i sonar_6.7.1_all.deb
