So, I've been trying to get my wireless connection to work most of today. The only solutions I can find tell me to download various drivers or updates, usually as a first step. Some guides even tell me to wget scripts just for the diagnostics step.
This is not possible. I cannot connect via. ethernet to my router, as it is upstairs at the back of the house and the PC in question is downstairs at the front.
Is there some way I can find and download updates on my main PC, and transfer them via. USB to Lubuntu?
Is there somewhere I can find and then download and install the ath9k driver from a USB? (I am given to understand that it should come with the distro, but it certainly doesn't in Lubuntu 16.04).
Is there somewhere I can find and install NdisWrapper? I can't run the make commands in Lubuntu, as the "make" package is missing from Lubuntu, so I'd need a way to install the make package as well.
Asking in roughly the order of my preference.
EDIT:
Results of running partial commands below:
sudo lshw -C network
 *-network
   description: Ethernet interface
   product: 82566DM-2 Gigabit Network Connection
   vendor: Intel Corporation
   physical id: 19
   bus info: pci@0000:00:19.0
   logical name: enp0s25
   version: 02
   serial: 00:21:70:1d:6f:56
   capacity: 1Gbit/s
   width: 32 bits
   clock: 33MHz
   capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=1.4-0 latency=0 link=no multicast=yes port=twisted pair
   resources: irq:25 memory:fe9e0000-fe9fffff memory:fe9db000-fe9dbfff ioport:ecc0(size=32)
lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation 82Q35 Express DRAM Controller [8086:29b0] (rev 02)
Subsystem: Dell OptiPlex 755 [1028:0211]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:02.0 VGA compatible controller [0300]: Intel Corporation 82Q35 Express Integrated Graphics Controller [8086:29b2] (rev 02) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 26
Memory at fea00000 (32-bit, non-prefetchable) [size=512K]
I/O ports at ec90 [size=8]
Memory at d0000000 (32-bit, prefetchable) [size=256M]
Memory at feb00000 (32-bit, non-prefetchable) [size=1M]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:02.1 Display controller [0380]: Intel Corporation 82Q35 Express Integrated Graphics Controller [8086:29b3] (rev 02)
Memory at fea80000 (32-bit, non-prefetchable) [size=512K]
00:03.0 Communication controller [0780]: Intel Corporation 82Q35 Express MEI Controller [8086:29b4] (rev 02)
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at f0200800 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:03.2 IDE interface [0101]: Intel Corporation 82Q35 Express PT IDER Controller [8086:29b6] (rev 02) (prog-if 85 [Master SecO PriO])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 18
I/O ports at fe80 [size=8]
I/O ports at fe90 [size=4]
I/O ports at fea0 [size=8]
I/O ports at feb0 [size=4]
I/O ports at fef0 [size=16]
Kernel driver in use: ata_generic
Kernel modules: pata_acpi
00:03.3 Serial controller [0700]: Intel Corporation 82Q35 Express Serial KT Controller [8086:29b7] (rev 02) (prog-if 02 [16550])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 17
I/O ports at ec98 [size=8]
Memory at fe9da000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: serial
00:19.0 Ethernet controller [0200]: Intel Corporation 82566DM-2 Gigabit Network Connection [8086:10bd] (rev 02)
Flags: bus master, fast devsel, latency 0, IRQ 25
Memory at fe9e0000 (32-bit, non-prefetchable) [size=128K]
Memory at fe9db000 (32-bit, non-prefetchable) [size=4K]
I/O ports at ecc0 [size=32]
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 [8086:2937] (rev 02) (prog-if 00 [UHCI])
Subsystem: Dell Optiplex 755 [1028:0211]
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at ff20 [size=32]
Kernel driver in use: uhci_hcd
00:1a.1 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 [8086:2938] (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at ff00 [size=32]
00:1a.7 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 [8086:293c] (rev 02) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 22
Memory at fe9d9c00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation 82801I (ICH9 Family) HD Audio Controller [8086:293e] (rev 02)
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at fe9dc000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 [8086:2940] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: fe800000-fe8fffff
Prefetchable memory behind bridge: 00000000f0000000-00000000f01fffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1d.0 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 [8086:2934] (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at ff80 [size=32]
00:1d.1 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 [8086:2935] (rev 02) (prog-if 00 [UHCI])
I/O ports at ff60 [size=32]
00:1d.2 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 [8086:2936] (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at ff40 [size=32]
00:1d.7 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 [8086:293a] (rev 02) (prog-if 20 [EHCI])
Memory at ff980800 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev 92) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
00:1f.0 ISA bridge [0601]: Intel Corporation 82801IO (ICH9DO) LPC Interface Controller [8086:2914] (rev 02)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] [8086:2922] (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: Dell 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] [1028:0211]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 27
I/O ports at fe00 [size=8]
I/O ports at fe10 [size=4]
I/O ports at fe20 [size=8]
I/O ports at fe30 [size=4]
I/O ports at fec0 [size=32]
Memory at f0200000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 82801I (ICH9 Family) SMBus Controller [8086:2930] (rev 02)
Flags: medium devsel, IRQ 9
Memory at fe9d9b00 (64-bit, non-prefetchable) [size=256]
I/O ports at ece0 [size=32]
Kernel modules: i2c_i801
Sorry, I was a bit confused by the results when I ran those commands piped into grep (? or the other way around), so I thought I'd share the full results. 02.0 seems to be something to do with integrated graphics?
In case it helps, my wireless card is the TL-WN722N USB, not a PCI-E slot (although I have a PCI-E card I could try using, due to the nature of the Dell Optiplex 755 case I'd need to take a coping saw to the case to allow it to fit).
lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 003: ID 093a:2510 Pixart Imaging Inc. Optical Mouse
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 2357:010c
Bus 004 Device 002: ID 1a2c:0002 China Resource Smico., Ltd
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
lspci -nnk | grep 280 -A2
blank/null result
JimmyM
  • 123
Please download these files on some other computer and transfer them to the desktop of the Lubuntu machine with a USB key or similar:
https://github.com/lwfinger/rtl8188eu/archive/master.zip
http://mirrors.kernel.org/ubuntu/pool/main/d/dkms/dkms_2.2.0.3-2ubuntu11_all.deb
Now, on the desktop of the Lubuntu machine, install dkms:
cd ~/Desktop
sudo dpkg -i dkms*.deb
If it complains that there are missing dependencies, tell us what they are so we may download a few more packages to satisfy those missing. The missing packages will be found here: https://packages.ubuntu.com/xenial/dkms Please be certain to select 32-bit (i386) or 64-bit (amd64) as needed for your machine. Confirm:
arch
32-bit returns i686 and 64 bit is x86_64.
Please see @JimmyM's very helpful list below for a complete list.
Next, do:
cd ~/Desktop
unzip master.zip
sudo mv rtl8188eu  /usr/src
cd /usr/src
sudo dkms add ./rtl8188eu
sudo dkms build 8188eu/1.0
sudo dkms install 8188eu/1.0
sudo modprobe 8188eu
Your wireless should now be working.
chili555
  • 61,330
