I am a high school teacher and I would like to create a custom Ubuntu Live USB stick to use during exams. I know there are other questions discussing how to customize a live USB but I have some additional requirements and I'm wondering if it's at all possible to create a Live USB that fits my needs.
  • The Live USB should automatically log in a user with limited permissions.
  • The user should in no way what so ever be able to access the internet.
  • The Live Stick should come preinstalled with the program GeoGebra.
  • There should be a partition where the user can save documents that will be readable when inserting the USB stick into a Windows or Mac machine.
  • If possible, a big timer should be shown on the desktop showing how long the system has been running.
This is similar to the "GeoGebra Exam Stick" that GeoGebra provides, GeoGebra stick does not provide any customization however and it defaults to a german keyboard layout among other things.
Since the purpose is to use this Live USB during school exams, no internet access is simply a must. Is there any way to disable internet access entirely for a user?
Anwar
  • 77,855
Why don't you use Ubuntu constructor to create your own image of what you want?
https://www.maketecheasier.com/reconstructor-creating-your-own-ubuntu-distribution
For timer how about this?
http://ubuntu.pkgs.org/16.04/ubuntu-universe-i386/stopwatch_3.5-5_all.deb.html
Alternatively you may want to modify a 'conky-file' which usually has a segment which shows how long the system has been up and running.
https://www.linux.com/learn/how-install-and-configure-conky
As for preventing wireless access, surely the easiest thing to do is to disable it in the BIOS (it will depend on make and model of notebook) or switch the wireless on/off switch to off and ensure student does not have their hands near the wifi on/off switch.
Zanna
  • 72,312
Difficult to create a custom Ubuntu Live USB stick
It is possible but maybe a bit difficult to create a custom Ubuntu Live USB stick.
An installed system (in a USB stick)
  • An alternative is to create an installed system. It is straightforward to create a system that works in the same boot mode, UEFI or BIOS, as the computer was booted in when you create the installed system.
    If you remove (disconnect) the internal drive before you start the installation, things will be easier (and safer), particularly in UEFI mode.
  • An alternative is to start from a simple text based installed system that boots in both UEFI and BIOS mode and install whatever you need (graphical desktop environment, GeoGebra etc).
  • Make a compressed image or cloned copy of the system at this stage, because things may go wrong, and you may want to continue installing and tweaking from this stage. You can use Clonezilla for this task.
  • After installing the custom software (GeoGebra etc) and tweaking the system, I would remove [some of the] software that is necessary for connecting to the internet.
    sudo apt-get remove isc-dhcp-client network-manager network-manager-gnome
    sudo apt-get remove apt
    and after that remove packages that are no longer used. This makes it more difficult to re-install the tools to connect to the internet.
    sudo apt-get autoremove
    sudo apt-get autoclean
    sudo apt-get clean
  • Create a compressed image of the final system, which cannot connect to the internet. You can use Clonezilla for this task.
    Then you can create cloned copies in other drives, for example USB pendrives or memory cards.
Links
You can start reading these links and links from them,
help.ubuntu.com/community/Installation/UEFI-and-BIOS
AskUbuntu: Bootable Ubuntu USB with custom kernel
clonezilla.org
sudodus
  • 47,684
