I found a command to directly scp my file to a host (C) via another host (B) from my computer. The command is in this form:
scp -oProxyCommand="ssh -W %h:%p B" thefile C:destination
I used it and it works good in command line. but when I want to write an expect script using this command, I got some errors. the script I've written is in this form:
#!/usr/bin/expect
set arg1 [lindex $argv 0]
spawn scp -oProxyCommand="ssh -W %h:%p B" ./$arg1 C:destination
interact
and the error is:
unknown option -- W
W option works in command line but not in expect script. Can anybody tell me why?
steeldriver
  • 142,475
Much easier would be to configure this in the ~/.ssh/config, where you don't need to care about the syntax of the expect scripts and its issues with arguments. Create ~/.ssh/config with this content:
Host C
  ProxyCommand ssh -W %h:%p B
and then connect just using
spawn scp ./$arg1 C:destination
Or just use the simplified version using ProxyJump option:
spawn scp -oProxyJump=B ./$arg1 C:destination
Jakuje
  • 6,793
