I've updated my Ubuntu distro, and since then everytime I boot the system I am stuck at the fsck screen
/dev/sda1: clean xxx/xxx files, xxx/xxx blocks
I`ve already trying accessing tty and installing xorg and/or nvidia drivers but keep getting the same error message from sudo apt-get install:
apt-get: relocation error: /usr/lib/x86_64-linux-gnu/libapt-pkg.so.5.0: symbol....
I had a GPU installed in my system at the time of the distro upgrade, but I've also tried a multitude of "fixes" with the GPU deactivated by the BOOT settings and none seem to work neither.
Can anyone help me with that? Thanks
Edit 1: Following the demand on a comment, I loged into recovery root and:
# sudo blkid
/dev/sdb: PTUUID="000d2ed6" PTTYPE="dos"
/dev/sata1: UUID="6ad5e12f-8d6f-4659-b5d4-8fe9eb9d11df" TYPE="ext4" PARTUUID="c537cdcf-01"
# cat /etc/fstab/
# /etc/fstab: static file system information
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with a UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=6ad5e12f-8d6f-4659-b5d4-8fe9eb9d11df / ext4 errors=remount-ro 0 1
# free -h
total used free shared buff/cache availabe
Mem: 7.7G 37M 7.5G 8.2M 162M 7.4G
Swap: 0B 0B 0B
# swap on
# _ (no output here)
