After asking a question on ubuntuforums.org and not getting a satisfying answer, I've decided to ask the question again here on Ask Ubuntu. I need the answer to be very detailed. Specifically, I need to know which lines get compared every time a line is printed using uniq for the following two examples:
file1.txt:
$ cat -A file1.txt
aaa^Iupc$
b$
c$
aaa^Iztp$
b$
c$
C$
A$
B$
B$
b$
$ sort file1.txt | uniq -f 1
A
aaa    upc
aaa    ztp
b
and file2.txt:
$ cat -A file2.txt
aaa^Iupc$
b$
c$
aaa^Iztp$
b$
c$
C$
A$
B$
B$
bbb^Ixpz$
$ sort file2.txt | uniq -f 1
A
aaa    upc
aaa    ztp
b
bbb    xpz
c
I'm confused about the second example. I don't understand how come uppercase B doesn't end up in the final output. Shouldn't the line with uppercase B be printed given that lines B and bbb xpz are both adjacent to each other? If:
B ---> (empty)
and
bbb ---> xpz
an empty value and xpz are both unique so both lines should be printed. Or am I missing something?
muru
  • 207,228
The answer lies in the sorting order and what does uniq uses for a field value when less than the given field number (N) exists while using -f N.
As seen you have ASCII charsets, so the sorting order is much predictable:
% sort file.txt
A
aaa upc
aaa ztp
b
b
B
B
bbb xpz
c
c
C
Now, let's use uniq -f 1 to get unique lines with skipping the (whitespace separated) first field of each line while checking:
% sort file.txt | uniq -f 1
A
aaa upc
aaa ztp
b
bbb xpz
c
Now, the important thing to note that, uniq uses null string for lines that has has less than the fields mentioned, 1 in this case; so, all the lines that has only one field would be treated as having null strings for other fields while comparing with other lines having >=2 fields.
So, from the sort file2.txt output:
b
b
B
B
would all be treated as same and only the first line containing b would be preserved, hence you have a b in the output.
Similarly, from:
c
c
C
only the first c would end up in the uniq's output.
heemayl
  • 93,925
Here's a table that may help you to work through the process:
    sort        |     Remove    | Adjacent |                |
 (C locale)     |    field #1   |  match?  |    Output      |
A               |               |    N*    |A               |
B               |               |    Y     |                |
B               |               |    Y     |                |
C               |               |    Y     |                |
aaa     upc     |   upc         |    N     |aaa     upc     |
aaa     ztp     |   ztp         |    N     |aaa     ztp     |
b               |               |    N     |b               |
b               |               |    Y     |                |
bbb     xpz     |   xpz         |    N     |bbb     xpz     |
c               |               |    N     |c               |
c               |               |    Y     |                |
* the first line has no adjacent above, so is always output
steeldriver
  • 142,475
