I have gcc 4.8 installed but I also need to install gcc 3.4.3. I have followed these steps:
  1. Downloaded gcc 3.4.3 from gcc.parentingamerica.com/releases.
  2. Extracted the tar.
  3. ./configure
  4. make
Then it throws this error: http://paste.ubuntu.com/24807240/
Please can anyone suggest what's wrong and also how to ask gcc to use the older version once installed?
OS: Ubuntu 14.04 LTS, 64-bit
ankit7540
  • 4,195
Check your current version by running gcc -v.
Next, You want to install a previous version.
  1. For gcc-3.4
Since this version is available in the older releases of Ubuntu, we need to have the appropriate repositories for the version. From some search, I found them to be the following, which have to be added to the /etc/apt/sources.list
deb     http://snapshot.debian.org/archive/debian/20070730T000000Z/ lenny main
deb-src http://snapshot.debian.org/archive/debian/20070730T000000Z/ lenny main
deb     http://snapshot.debian.org/archive/debian-security/20070730T000000Z/ lenny/updates main
deb-src http://snapshot.debian.org/archive/debian-security/20070730T000000Z/ lenny/updates main
Then after doing sudo apt-get update the new repositories will be available.
Next, install the required compiler. I usually install gcc and g++ of the same version for inter-operability. For general purpose it is recommended.
Hence,
sudo apt-get install gcc-3.4 g++-3.4
2. Checking the available compilers
At this stage one will have two set of compilers (one each for g++ and gcc). These can be checked by dpkg --list | grep compiler,
ii  g++                                                   4:4.8.2-1ubuntu6                                    amd64        GNU C++ compiler
ii  g++-3.4                                               3.4.6-5                                             amd64        The GNU C++ compiler
ii  g++-4.8                                               4.8.4-2ubuntu1~14.04.1                              amd64        GNU C++ compiler
ii  gcc                                                   4:4.8.2-1ubuntu6                                    amd64        GNU C compiler
ii  gcc-3.4                                               3.4.6-5                                             amd64        The GNU C compiler
ii  gcc-4.8                                               4.8.4-2ubuntu1~14.04.1                              amd64        GNU C compiler
ii  hardening-includes                                    2.5ubuntu2.1                                        all          Makefile for enabling compiler flags for security hardening
ii  libllvm3.6:amd64                                      1:3.6-2ubuntu1~trusty1                              amd64        Modular compiler and toolchain technologies, runtime library
ii  libxkbcommon0:amd64                                   0.4.1-0ubuntu1                                      amd64        library interface to the XKB compiler - shared library
ii  pkg-config                                            0.26-1ubuntu4                                       amd64        manage compile and link flags for libraries
You can check the installation location if you need that.
Important is the location of the two set of compilers, which can be listed by,
ls -lh /usr/bin/gcc*
lrwxrwxrwx 1 root root    7  5月 13  2016 /usr/bin/gcc -> gcc-4.8
-rwxr-xr-x 1 root root  91K  1月  4  2007 /usr/bin/gcc-3.4
-rwxr-xr-x 1 root root 758K  1月 27  2016 /usr/bin/gcc-4.8
and
    ls -lh /usr/bin/g++*
lrwxrwxrwx 1 root root    7  4月  8  2014 /usr/bin/g++ -> g++-4.8
-rwxr-xr-x 1 root root  93K  1月  4  2007 /usr/bin/g++-3.4
-rwxr-xr-x 1 root root 758K  1月 27  2016 /usr/bin/g++-4.8
  1. Selecting a compiler for current purpose (building an application)
After having required compilers installed one can simply switch among compilers. This is done by updating the list of alternative versions of an application. To do this, the update-alternative command has to be run with certain parameters.
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.8 60 --slave /usr/bin/g++ g++ /usr/bin/g++-4.8
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-3.4 40 --slave /usr/bin/g++ g++ /usr/bin/g++-3.4
sudo update-alternatives --config gcc
This will link g++ to gcc and on changing only gcc the g++ will change automatically.
Then whenever you want to change the compiler enter this:
Then, user is asked which compiler to choose.
    There are 2 choices for the alternative gcc (providing /usr/bin/gcc).
      Selection    Path              Priority   Status
    * 0            /usr/bin/gcc-4.8   60        auto mode
      1            /usr/bin/gcc-3.4   40        manual mode
      2            /usr/bin/gcc-4.8   60        manual mode
Press enter to keep the current choice[*], or type selection number:
Here you can choose by pressing the key(0,1) and then pressing enter. The change in the current selected version can be checked by gcc -v
Removing the update-alternative
  1. If you want to keep the alternative compiler installed. Then just change to auto mode in update-alternative that is option 0.
  2. If you want to remove the alternative compiler, then remove the compiler like as sudo apt-get remove gcc-3.4 g++-3.4 then run
The program update-alternatives will look for links and found them to be missing and will automatically remove the alternative, going back to the other available option.
update-alternatives: warning: alternative /usr/bin/gcc-3.4 (part of link group gcc) doesn't exist; removing from list of alternatives
There is only one alternative in link group gcc (providing /usr/bin/gcc): /usr/bin/gcc-4.8
Nothing to configure.
ankit7540
  • 4,195
It's not possible to have to versions of the same package, as they would be conflicting files,for example: you'd have trouble while trying to update one of the packages as they would be placed in the same location.
Having said that you have the option to downgrade the version of the program to an older one, here comes the how to:
  1. open a terminal emulator and type apt-cache showpkg <package-name> a list of the available versions will be printed
  2. Then type sudo apt-get install <package-name>=<package-version-number> to install the version you prefer
  3. type apt-mark hold <package-name> this will prevent the package from being updated
  4. if you have any trouble type man apt to open the command's manual
muru
  • 207,228
