From root, where can I access the C: drive on my Windows partition?
Asked
Active
Viewed 332 times
Technically it will be available under /media/Your-User-Name/UUID-Of-Partition/, only if your first mount it using GUI, e.g:
/media/ravexina/af01656da-2149-9e293/
You can use:
ls -l /dev/disk/by-uuid/ | grep -i sd
to have a list of your partitions UUID's.
or:
sudo blkid /dev/sda1
for a specific partition.
Otherwise first you should find out which one of your partitions are actual "C:\" you can use fdisk for this purpose, e.g if your hard drive is /dev/sda then:
sudo fdisk -l /dev/sda
gives you a list of your partitions:
/dev/sda1 * 2048 999423 997354
/dev/sda2 * 1001470 9767710 97576960
Alternatively you can use grep sd /proc/partitions too.
then you can figure out which one of them is your "C:\" drive (Based on the partition size).
After that mount them somewhere, let's say /dev/sda1 is your "C:\" drive:
sudo mount /dev/sda1 /mnt
now it will be available to you at /mnt
Ravexina
- 57,256
