Ubuntu version 16.04
This is what I get when running
sudo apt-get install --fix-missing
Even when I want to download freecad from terminal also got the same error.
code:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
24 not fully installed or removed.
Need to get 316 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://id.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libfreetype6 amd64 2.6.1-0.1ubuntu2.3 [316 kB]
Fetched 316 kB in 2s (110 kB/s)
dpkg: error processing package libfreetype6:amd64 (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
No apport report written because the error message indicates its a followup error from a previous failure.
                                                    No apport report written because MaxReports is reached already
                                  dpkg: dependency problems prevent configuration of grub-common:
 grub-common depends on libfreetype6 (>= 2.2.1); however:
  Package libfreetype6:amd64 is not configured yet.
dpkg: error processing package grub-common (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of grub2-common:
 grub2-common depends on grub-common (= 2.02~beta2-36ubuntu3.9); however:
  Package grub-common is not configured yet.
dpkg: error processing package grub2-common (--configure):
dpkg: dependency problems prevent configuration of grub-pc-bin:
 grub-pc-bin depends on grub-common (= 2.02~beta2-36ubuntu3.9); however:
dpkg: error processing package grub-pc-bin (--configure):
dpkg: dependency problems prevent configuration of grub-pc:
 grub-pc depends on grub-common (= 2.02~beta2-36ubuntu3.9); however:
  Package grub-common is No apport report written because MaxReports is reached already
                                                 not configured yet.
 grub-pc depends on grub2-common (= 2.02~beta2-36ubuntu3.9); however:
  Package grub2-common is not configured yet.
 grub-pc depends on grub-pc-bin (= 2.02~beta2-36ubuntu3.9); however:
  Package grub-pc-bin is not configured yet.
dpkg: error processing package grub-pc (--configure):
dpkg: dependency problems prevent configuration of libmagickcore-6.q16-2:amd64:
 libmagickcore-6.q16-2:amd64 depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package libmagickcore-6.q16-2:amd64 (--configure):
dpkg: dependency problems prevent configuration of libmagickwand-6.q16-2:amd64:
 libmagickwand-6.q16-2:amd64 depends on libmagickcore-6.q16-2 (>= 8:6.8.9.9); however:
  Package libmagickcore-6.q16-2:amd64 is not configured yet.
dpkg: error processing package libmagickwand-6.q16-2:amd64 (--configure):
 dependency problems - leaviNo apport report written because MaxReports is reached already
                                           ng unconfigured
dpkg: dependency problems prevent configuration of firefox:
 firefox depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package firefox (--configure):
dpkg: dependency problems prevent configuration of libwebkit2gtk-4.0-37:amd64:
 libwebkit2gtk-4.0-37:amd64 depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package libwebkit2gtk-4.0-37:amd64 (--configure):
dpkg: dependency problems prevent configuration of gir1.2-webkit2-4.0:amd64:
 gir1.2-webkit2-4.0:amd64 depends on libwebkit2gtk-4.0-37 (>= 2.15.90); however:
  Package libwebkit2gtk-4.0-37:amd64 is not configured yet.
dpkg: error processing package gir1.2-webkit2-4.0:amd64 (--configure):
dpkg: dependency problems prevent configuration of imagemagick-6.q16:
 imagemagick-6.q16 depends on libmagickcore-6.q16-2 (>= 8:6.8.8.2); however:
 imagemagick-6.q16 depends on libmagickwand-6.q16-2 (>= 8:6.8.8.2); however:
  Package libmagickwand-6.q16-2:amd64 is not configured yet.
dpkg: error processing package imagemagick-6.q16 (--configure):
dpkg: dependency problems prevent configuration of imagemagick:
 imagemagick depends on imagemagick-6.q16 (= 8:6.8.9.9-7ubuntu5.7); however:
  Package imagemagick-6.q16 is not configured yet.
dpkg: error processing package imagemagick (--configure):
dpkg: dependency problems prevent configuration of libgd3:amd64:
 libgd3:amd64 depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package libgd3:amd64 (--configure):
dpkg: dependency problems prevent configuration of libmagickcore-6.q16-2-extra:amd64:
 libmagickcore-6.q16-2-extra:amd64 depends on libmagickcore-6.q16-2 (>= 8:6.8.9.9); however:
 libmagickcore-6.q16-2-extra:amd64 depends on libmagickwand-6.q16-2 (>= 8:6.8.8.2); however:
dpkg: error processing package libmagickcore-6.q16-2-extra:amd64 (--configure):
dpkg: dependency problems prevent configuration of libqt4-opengl:amd64:
 libqt4-opengl:amd64 depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package libqt4-opengl:amd64 (--configure):
dpkg: dependency problems prevent configuration of libqt4-opengl-dev:
 libqt4-opengl-dev depends on libqt4-opengl (= 4:4.8.7+dfsg-5ubuntu2); however:
  Package libqt4-opengl:amd64 is not configured yet.
dpkg: error processing package libqt4-opengl-dev (--configure):
dpkg: dependency problems prevent configuration of libwebkit2gtk-4.0-37-gtk2:amd64:
 libwebkit2gtk-4.0-37-gtk2:amd64 depends on libwebkit2gtk-4.0-37 (= 2.16.3-0ubuntu0.16.04.1); however:
 libwebkit2gtk-4.0-37-gtk2:amd64 depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package libwebkit2gtk-4.0-37-gtk2:amd64 (--configure):
dpkg: dependency problems prevent configuration of python3-pil:amd64:
 python3-pil:amd64 depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package python3-pil:amd64 (--configure):
dpkg: dependency problems prevent configuration of thunderbird:
 thunderbird depends on libfreetype6 (>= 2.2.1); however:
dpkg: error processing package thunderbird (--configure):
dpkg: dependency problems prevent configuration of thunderbird-gnome-support:
 thunderbird-gnome-support depends on thunderbird (= 1:52.1.1+build1-0ubuntu0.16.04.1); however:
  Package thunderbird is not configured yet.
dpkg: error processing package thunderbird-gnome-support (--configure):
dpkg: dependency problems prevent configuration of thunderbird-locale-en:
 thunderbird-locale-en depends on thunderbird (>= 1:52.1.1+build1-0ubuntu0.16.04.1); however:
 thunderbird-locale-en depends on thunderbird (<< 1:52.1.1+build1-0ubuntu0.16.04.1.1~); however:
dpkg: error processing package thunderbird-locale-en (--configure):
dpkg: dependency problems prevent configuration of thunderbird-locale-en-gb:
 thunderbird-locale-en-gb depends on thunderbird-locale-en; however:
  Package thunderbird-locale-en is not configured yet.
dpkg: error processing package thunderbird-locale-en-gb (--configure):
dpkg: dependency problems prevent configuration of thunderbird-locale-en-us:
 thunderbird-locale-en-us depends on thunderbird-locale-en; however:
dpkg: error processing package thunderbird-locale-en-us (--configure):
dpkg: dependency problems prevent configuration of thunderbird-locale-id:
 thunderbird-locale-id depends on thunderbird (>= 1:52.1.1+build1-0ubuntu0.16.04.1); however:
 thunderbird-locale-id depends on thunderbird (<< 1:52.1.1+build1-0ubuntu0.16.04.1.1~); however:
dpkg: error processing package thunderbird-locale-id (--configure):
 libfreetype6:amd64
 grub-common
 grub2-common
 grub-pc-bin
 grub-pc
 firefox
 imagemagick-6.q16
 imagemagick
 libgd3:amd64
 libqt4-opengl:amd64
 libqt4-opengl-dev
 python3-pil:amd64
 thunderbird
my source list:
deb cdrom:[Ubuntu 16.04.2 LTS _Xenial Xerus_ - Release amd64 (20170215.2)]/ xenial main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://id.archive.ubuntu.com/ubuntu/ xenial main restricted
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://id.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://id.archive.ubuntu.com/ubuntu/ xenial universe
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial universe
deb http://id.archive.ubuntu.com/ubuntu/ xenial-updates universe
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://id.archive.ubuntu.com/ubuntu/ xenial multiverse
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial multiverse
deb http://id.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://id.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
# deb-src http://id.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu xenial partner
deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://security.ubuntu.com/ubuntu xenial-security main restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu xenial-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
edwinksl
  • 24,109
I also got this issue. Try running these commands one by one
sudo apt-get update
sudo apt-get upgrade
sudo apt-get -f install
These steps helped me for fixing this issue.
