I have a very common problem with my Ubuntu 16.04 LTS/MySQL 5.7.18/WordPress running on a Digital Ocean droplet with 2 CPU, 40GB SSD and 16GB RAM. The droplet is only running one site and has hardly any traffic because it is still under development.
  1. I cannot connect via 'mysql -u root -p'.
  2. I cannot use the 'sudo mysqlsecureinstallation' script.
Every time after entering the password I get the dreaded "Access denied for user 'root'@'localhost' (using password: YES)" error message.
This appears to be a very common problem. I wasted a whole day following all the usual recommendations, such as reinstalling MySQL, with and without prior uninstall, crossgrading to MariaDB and back to MySQL, all to none avail. What am I doing wrong?
Btw, the WordPress site is working fine. The problem only became apparent when I added Moodle to the installation and got stuck at the point where you need to create the Moodle tables. Since I cannot log into the MySQL server, I'm now stuck.
Wink
Make sure you'v started mysql.
mysql -h 127.0.0.1 -u root
if you'v not set mysql password you should not include -p, notice you have to specify the host
Tobi Obadiah
  • 162
  • 17
