Hello community I'm the newbiest Ubuntu user ever. I'm also Computer Science student migrating to this operation system and looking for clean IDE to build my algorithms. I found one called "Builder" but it is not working properly. I faced two errors, first one was saying to install autopoint after that the second one showed up saying it:
autoreconf: Entering directory `.'
autoreconf: running: autopoint --force
autoreconf: running: aclocal --force
configure.ac:102: error: m4_defn: undefined macro: LT_PACKAGE_VERSION
m4/libtool.m4:40: LT_PREREQ is expanded from...
configure.ac:102: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: error: echo failed with exit status: 1
autoreconf: aclocal failed with exit status: 1
Any ideas to solve this error?
steeldriver
  • 142,475
In ubuntu 17.04 gnome-builder package has dependency problem for autotools.
To fix this you need to add two packages more: autopoint, libtool-bin.
Execute this in terminal:
sudo apt install autopoint libtool-bin
In your case, you have installed autopoint already, so just install libtool-bin.
