(Important for readers and AskUbuntu editors: I know my 12.04 has reached its EOL, but I'm asking for an upgrade, so please do not set my question as off-topic.)
I'm using Ubuntu 12.04.5 LTS Precise Pangolin as dual-boot with Windows 7. I know that my installation has reached its End Of Life and I was wondering if I could upgrade from 12.04.5 LTS to 14.04.5 LTS, but with some modifications. My graphics card is not fully supported for the Unity 3D Interface, so I was wondering if I could upgrade to Trusty Tahr, remove Unity somehow and add GNOME (3.x or 2.x, whatever it installs) and use it as my main desktop environment. I have also tried GNOME 3 (using a Debian 8 live DVD) and my PC can handle that. With GNOME 2 (Classic/Fallback Session), no problems at all.
So, can I do so? Can I upgrade to 14.04 and use GNOME as my main desktop environment?
My computer specifications:
Dell Optiplex GX270 SFF (Small-Form-Factor)
  • Operating Systems: Windows 7 & Ubutnu 12.04.5 LTS Precise Pangolin
  • Partitioning: Windows 7 (/dev/sda2, NTFS, 5.80/40.80 GB free) dev/sda3 -> Extended Partition (Ubuntu + Swap) Ubuntu (/dev/sda5, ext4, 5.02/14.00 GB free) Swap Partition (/dev/sda6, linux-swap, 1020.00 MB)
  • Motherboard: Dell Corp. 0YF936
  • RAM: 1024 MB (1GB)
  • CPU: Intel Corporation Pentium 4 @ 2.40 GHz
  • Graphics Card: Intel HD Graphics 82865G, 1280x1024
  • Hard Disk: Western Digital WD600BB-00CA
Thanks in advance,
Bajiru
na-no.
  • 856
  • 24
I installed 14.04 and it's working fine (with GNOME Flashback)
I deleted my previous 12.04.5 LTS installation (because upgrading is as slow as hxxl and I backed up my files), I installed 14.04.5 LTS this morning, logged in, installed GNOME, and it was working! I am using now GNOME Flashback (Metacity) because the others are slow (GNOME 3 Normal is the slowest of all GNOME desktop environments on my PC, Unity is the slowest of all) and I am OK. I found the answer to my own question!
Bajiru
(P.S.: Sorry for the h- word above)
na-no.
  • 856
  • 24
-1
I don't understand why you can't just upgrade to 16.04.
I'm running 16.04 on an older machine with Xfce desktop (which I highly recommend, but that's beside the point). The xwindoing environment really doesn't have much to do with the actual system, meaning you can purge or install it like a program. Press Ctrl+Alt+F1 to get into a tty session (you want to be out of Unity) and run the following:
sudo apt-get purge unity-desktop
Once it finishes:
sudo apt-get install gnome-desktop
Then restart:
sudo reboot
Now you may not be able to install gnome before you upgrade, so I would upgrade first:
sudo do-release-upgrade
And then once the machine boots into 16.04, enter the tty session when you get the login prompt and run those commands.
Zanna
  • 72,312
