There is no php.ini after installing php (7.1) on ubuntu 16.04
I installed php using apt install php. I already tried to find the php.ini using the find command, but there is no file called php.ini anywhere.
Florian
  • 61
5 Answers5
I recently setup a wordpress server and ran into this same issue.
I used apt-get install php
Everything seemed to be normal except I could not find the php.ini file either. That file is usually located in /etc/php/7.0/apache2/php.ini
My solution, and I guess is also your solution would be that apache mod didn't get installed for php. So all you need to run is apt-get install libapache2-mod-php
I also bounced apache just to be safe, but then my php.ini file was then located where I expected it in /etc/php/7.0/apache2/php.ini
Espi
  • 43
Try using the command php --ini. Since you're running command line, it won't necessarily show you the config files you may be looking for (apache, nginx, etc), but it will hopefully get you on the right path.
When I run it I see:
$ php --ini
Configuration File (php.ini) Path: /etc/php/7.0/cli
Which tells me if I'm looking for Apache files, I can find the rest up one directory from there:
$ ls /etc/php/7.0/
apache2  cli  fpm  mods-available
If all else fails, and you're able to browse to a .php file on the server, create a file using phpinfo like this and take a look to see what ini files are in use:
<?php
phpinfo();
Kindly use the locate command instead. Here is my output:
subroot@subroot:~$ find php.ini
find: ‘php.ini’: No such file or directory
subroot@subroot:~$ locate php.ini
/etc/php/7.0/apache2/php.ini.ucf-dist
/etc/php/7.0/apache2/php.ini.ucf-old
/etc/php/7.0/cli/php.ini
/etc/php/7.1/apache2/php.ini
/etc/php/7.1/apache2/php.ini.ucf-dist
/etc/php/7.1/cli/php.ini
/usr/lib/php/5.6/php.ini-development
/usr/lib/php/5.6/php.ini-production
/usr/lib/php/5.6/php.ini-production.cli
/usr/lib/php/7.0/php.ini-development
/usr/lib/php/7.0/php.ini-production
/usr/lib/php/7.0/php.ini-production.cli
/usr/lib/php/7.1/php.ini-development
/usr/lib/php/7.1/php.ini-production
/usr/lib/php/7.1/php.ini-production.cli
subroot@subroot:~$
Type man find and man locate for the difference between the two commands.
Parto
  • 15,647
If you don't see the php module just install it.
sudo apt install php
php is not bundled with apache out of the box. You may also have to additional steps. Check here: https://www.serverlab.ca/tutorials/linux/web-servers-linux/installing-php-for-apache-on-ubuntu/
Gilboot
  • 121
You may have passed the wrong options to find, just like Parto did in his answer.
Try this find command:
find / -iname '*php.ini*'
