How can I get the IP address of an LXC container in a format I can use in scripting?
Right now, the command lxc info <container> report that information, but in a human readable format, with a lot of information.
I would like to ONLY to GET the IP address given a container name.
Note: I HAVE to duplicate this question because Linux Containers have changed a lot.
Installing lxd and using unprivileged containers is the default way to go this days (2017) and I think the solutions posted on the original question are do not resolve the issue in this case.
In any case, I installed the package lxc1 to get access to the command lxc-info, but that command doesn't recognize any of my unprivileged containers.
jgomo3
  • 716
8 Answers8
A native solution (which isn't any prettier than @siloko's answer) would be
lxc list "<name>" -c 4 | awk '!/IPV4/{ if ( $2 != "" ) print $2}'
There are alternatives to awk, but that's tangential to the question.
Jonathan Y.
  • 1,054
So far this is the easiest way:
lxc list -c4 --format csv <container> | cut -d' ' -f1
But maybe it will be possible without cut.
EDIT: Uncut bash:
a=( $(lxc list -c4 --format csv u1) ) ip4=$a[1] echo $ip4
Hint from @monstermunchkin from the above issue.
lxc list | grep nameofthecontainer | egrep -o "[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+"
This is what I am using, I pass the container name in as a variable.
muru
  • 207,228
Neil
pylxd is the official python API client interface developed, supported, and endorsed by the LXD project.
Installation instructions here
$ python3
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
>>> from pylxd import Client
>>> client = Client()
>>> for p in client.containers.all(): print(p.name, p.state().network['eth0']['addresses'][0]['address'])
stretch-cc 10.76.67.242
These use a single grep.
For IPv4:
lxc info container-name |grep -Po '\seth\d:\sinet\s+\K[0-9\.]+'
For IPv6 (will probably list multiple IPs):
lxc info container-name |grep -Po '\seth\d:\sinet6\s+\K[0-9a-f:]+'
bitinerant
  • 1,157
Install jq:
sudo apt-get install jq
The function get_lxc_container_ip has 4 arguments:
  • arg1: container name
  • arg2(optional): family, inet(default) or inet6
  • arg3(optional): interface, default values are both eth0 and enp5s0
  • arg4(optional): scope, global(default), link or local
Exit status:
  • 0: success
  • 4: no valid result
  • 1 (not likely): jq last output value was either false or null
  • 2 (not likely): jq usage problem or system error
  • 3 (not likely): jq program compile error
get_lxc_container_ip() {
    local container=$1
    local family=${2:-inet}
    local interface=\"${3:-'eth0", "enp5s0'}\"
    local scope=${4:-global}
    lxc list --format json |
        jq -re 'try .[] | select (.name == "'"$container"'")
            | .state.network | to_entries[]
            | select(.key == ('"$interface"')).value.addresses[]
            | select((.family == "'"$family"'") and (.scope == "'"$scope"'"))
            | .address'
Since a container can create many interfaces (e.g. run docker/lxd inside the container with security.nesting=true), other ways based on text filtering may get inaccurate result. jq does not have this problem.
Be aware that some interfaces may have multiple IP addresses (e.g. family=inet6 and scope=global), you may need to pipe it to head -1 to get the first result.
Probably a bit ugly but:
lxc-info -n my-container | grep IP: | tr -d ' ' | cut -f2 -d:
will get you just the IP address
slowko
  • 932
-1
lxc-info --name container --ips --no-humanize
prints the container IP addresses.
The returned value is a list because a container can have more than one address.
