I have installed cuda via a package manager. The installation seems to be successful:
$ nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver Copyright (c) 2005-2016 NVIDIA Corporation Built on Sun_Sep__4_22:14:01_CDT_2016 Cuda compilation tools, release 8.0, V8.0.44
And when I type which nvcc I get /usr/bin/nvcc. However, I think the cuda directory is not actually there:
$ ls -a /usr/local/bin
.   easy_install      f2py  gitsome      tensorboard   theano-nose
xonsh.bat ..  easy_install-2.7  gh    gitsome.bat  theano-cache  xonsh
Is cuda actually installed, and if it is - where?
After running dpkg --get-selections | grep cuda I get the following output:
libcuda1-375                        install
libcudart8.0:amd64              install
nvidia-cuda-dev                 install
nvidia-cuda-doc                 install
nvidia-cuda-gdb                 install
nvidia-cuda-toolkit             install
David Foerster
  • 36,890
  • 56
  • 97
  • 151
CUDA seems to be successfully installed. It should get installed in /usr/local/.
Try checking with
This command shows the following result for successfully installed cuda7.5: result of above command after installing cuda 7.5
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Nidhi
