I installed the latest version of Eclipse using the installer wizard. (I was following the instructions in the following link.)
I can run eclipse from the command line as follows:
$ ~/eclipse/java-neon/eclipse/eclipse
I was wondering if I could set it up so that I can run Eclipse by just typing:
$ eclipse
However, I am not sure whether it is "better"
to add the folder ~/eclipse/java-neon/eclipse/ to the PATH,
or to add a symbolic link to the eclipse executable
to one of the directories in the current PATH.
(In case it is recommended to add a symbolic link,
which of the directories is preferred?)
