On Ubuntu 16.04, I've already followed a couple of tutorials to rebuild network-manager, also installed via apt-get install network-manager-l2tp network-manager-l2tp-gnome.
It was working until yesterday, when a random message saying The VPN connection failed because the VPN service failed to start. There is no errors in configuration since the same VPN credentials and host are been using in another Ubuntu, also 16.04, and Windows 8.1.
Looking on /var/log/syslog:
NetworkManager[899]: <info> [1496143714.1953] audit: op="connection-activate" uuid="cac1651d-9cbd-4989-bc57-b9707ddd012a" name="VPNCS" pid=2295 uid=1000 result="success"
NetworkManager[899]: <info> [1496143714.1973] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: Started the VPN service, PID 5798
NetworkManager[899]: <info> [1496143714.2013] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: Saw the service appear; activating connection
NetworkManager[899]: <info> [1496143714.2760] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: VPN connection: (ConnectInteractive) reply received
NetworkManager[899]: nm-l2tp[5798] <info> ipsec enable flag: yes
NetworkManager[899]: ** Message: Check port 1701
NetworkManager[899]: nm-l2tp[5798] <info> starting ipsec
NetworkManager[899]: Stopping strongSwan IPsec...
gnome-session[1843]: X protocol error:
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22167, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22168, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22169, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22170, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22171, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22172, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22173, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22174, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22175, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22176, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22177, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22178, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22179, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22180, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22181, major_opcode = 33, minor_opcode = 0
gnome-session[1843]: <class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x00e003ad), sequence_number = 22182, major_opcode = 33, minor_opcode = 0
NetworkManager[899]: Starting strongSwan 5.5.2 IPsec [starter]...
NetworkManager[899]: Loading config setup
NetworkManager[899]: Loading conn 'cac1651d-9cbd-4989-bc57-b9707ddd012a'
NetworkManager[899]: found netkey IPsec stack
charon: 00[DMN] Starting IKE charon daemon (strongSwan 5.5.2, Linux 4.4.0-78-generic, x86_64)
NetworkManager[899]: nm-l2tp[5798] <warn> IPsec service is not ready.
NetworkManager[899]: nm-l2tp[5798] <warn> Could not establish IPsec tunnel.
NetworkManager[899]: (nm-l2tp-service:5798): GLib-GIO-CRITICAL **: g_dbus_method_invocation_take_error: assertion 'error != NULL' failed
NetworkManager[899]: <info> [1496143732.4905] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: VPN plugin: state changed: stopped (6)
NetworkManager[899]: <info> [1496143732.4929] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: VPN plugin: state change reason: unknown (0)
NetworkManager[899]: <info> [1496143732.4952] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: VPN service disappeared
NetworkManager[899]: <warn> [1496143732.4971] vpn-connection[0xa56420,cac1651d-9cbd-4989-bc57-b9707ddd012a,"VPNCS",0]: VPN connection: failed to connect: 'Message recipient disconnected from message bus without replying'
I've already tried removing network-manager-l2tp and -gnome packages and reinstalling them but I still have the same error.
Any fix?
