I have a problem booting Windows 10 from grub. When I tried to do it I got this message:
/EndEntire
file path: /ACPI....../File(bootmgfw.efi)/EndEntire
error: cannot load image.
I then Googled and found this solved problem, which tells you to edit the grub.cfg file.
Edit
/boot/grub/grub.cfgFind
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 10 (loader) (on /dev/sdXX)'After
chainloader +1Write
ntldr /bootmgr
When I tried to apply that I got this error, in addition to the original one
error: can't find command `ntldr'.
This might be due to my grub.cfg file not looking like the one in the link but I don't know how to adapt the solution.
As the grub.cfg file is quite lengthy, this is the section mentioned in the other solution.
menuentry 'Windows Boot Manager (on /dev/sda2)' --class windows --class os $menuentry_id_option 'osprober-efi-4CBE-1366' {
insmod part_gpt
insmod fat
set root='hd0,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint- efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 4CBE-1366
else
search --no-floppy --fs-uuid --set=root 4CBE-1366
fi
chainloader /EFI/Microsoft/Boot/bootmgfw.efi
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
The full file can be found here if needed.
I've tried to update grub, no difference.
Edit:
Output from terminal
kajsa@Yoga ~ $ sudo update-grub
[sudo] password for kajsa:
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-4.4.0-53-generic
Found initrd image: /boot/initrd.img-4.4.0-53-generic
Found Windows Boot Manager on /dev/sda2@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for EFI firmware configuration
done
Any suggestions?
