According to How is the /tmp directory cleaned up?, the /tmp directory is cleaned up using tmpreaper, which uses cron to schedule cleanups at fixed time intervals. However, I would instead like to enforce a certain maximum size of the tmp directory. Is this possible?
Asked
Active
Viewed 198 times
You could write a little script:
# your maximum size of /tmp in kbytes
maxsize=1000
# now get the actual size of /tmp in kbytes
tmpsize=$(du -ks /tmp|cut -f 1)
# when maximum reached, clean up
if [ $tmpsize -ge $maxsize ]; then
rm -r /tmp/*
fi
This should be run as root, in order to clean up files owned by other users (including root) as well.
