Heard about this, and immediately decided to get Ubuntu. I'm not interested in running Ubuntu alongside Windows, 'cause yeah. I just had one doubt, I'm currently downloading Ubuntu 11.10 32 bit. I've seen around the internet, that there's an option to dual boot. I've never done any of this in my life, and obviously, first time chills. So when I download Ubuntu, I understand I'm supposed to put it on a CD or a USB? Then try out this CD, etc etc etc. The question is, in all of this process, will I ever have the option of allowing dual boot? Or do I have to go around downloading what I see is called "Wubi" too? Deeply appreciated.
One more minor thing, after installing Ubuntu and living happily ever after, will everything I have currently in my laptop get deleted? Pictures, data, games, everything? Or transformed to be supported on Ubuntu? Thanks, if answered.
Happy new year!
Jorge Castro
  • 73,717
Yes, the graphical installer will present you with an option to keep Windows. What will happen is that you're asked how much space of the harddisk Windows should have access to, and how much Ubuntu should use. That's just a slider and you can choose 50%, for instance. You should be aware that while Windows is not capable of reading Ubuntus data, Ubuntu is capable of reading and writing to Windows' file system.
The difference between Wubi and a normal install in that regard, is that Wubi installs do not resize the Windows file system, but creates a folder in it where Ubuntu can be "installed". If you've heard of ISO images that's used instead of CD-ROM discs, that is the same type. Instead of simulating a CD-ROM in a file, wubi simulates a harddisk for Ubuntu to use. But this also means Wubi installs usually are less efficient and might also be less stable. A normal install is preferred, and is very easy to do. Just follow the onscreen instructions and you shouldn't have any difficulties.
But please do pay attention. For instance, if you choose not to keep windows, it cannot be undone afterwards. So make sure before you click. :)
Installing from a CD or USB stick will still allow you to install side-by-side with Windows if you want. There are instructions here:
http://www.ubuntu.com/download/ubuntu/download
If you click "Show me how" under Step 4 ("Install it!") you will see that one of the questions asked during install is whether or not to erase the entire disk or install alongside an existing operating system.
Some settings can be imported from a Windows partition if you perform a side-by-side install with Windows, but your documents and files will not be copied or moved automatically. You should back up your important files and copy them to your new Ubuntu installation once it is completed.
fader
  • 5,701
