How to upgrade from Ubuntu-12.04 LTS to the latest stable Ubuntu version, could someone please help me with the procedure, can I find a KB article somewhere. ? Thank you in advance.
The steps has to be incremental viz:
12.04 to 14.04 to 16.04 to 16.10 to 17.04
Step 1:
1a. 12.04 to 14.04:
Press Alt+F2 and type in "update-manager" (without the quotes) into the command box
Update Manager should open up and tell you: New distribution release '14.04 LTS' is available.
Click Upgrade and follow the on-screen instructions.
1b. Server editions:
Install the update-manager-core package if it is not already installed.
Launch the upgrade tool with the command sudo do-release-upgrade.
Follow the on-screen instructions.
Step 2: 14.04 to 16.04:
Make sure that you are fully up-to-date.
Trigger the update:
sudo update-manager -dThe Update Manager application will open after a few seconds. It will double-check you're up to date. It will display a prompt asking you if you want to upgrade. Just click the “Upgrade’ button to begin the process.
Wait for for the update manager to finish its work.
Step 3:
1a. 16.04 to 16.10 (Desktop)
First always backup important data, bookmarks, etc.
- disable or remove all third-party repositories on Other Software tab.
- select Open Source graphic driver in Additional Drivers and REBOOT after applied changes.
Open
Software & Updatesusing the Unity DashSelect the
UpdatestabFind the section titled
Notify me of a new Ubuntu versionChange this from
For long-term support versions toFor any new version`Click
CloseRun:
sudo apt update && sudo apt full-upgradeOpen terminal and run:
sudo update-manager -d, when thesoftware updaterappears selectupgrade
1b. 16.04 to 16.10 (Server):
sudo apt install update-manager-coresudo nano /etc/update-manager/release-upgrades- Change the line "Prompt=LTS" to "Prompt=normal" (without quotes) and save the file.
sudo do-release-upgrade -d
Step 4 16.10 to 17.04:
Always make a backup of important data, bookmarks, and other user documents.
Remove or disable third-party repositories:
- Launch Software & Updates utility, navigate to Other Software tab, and remove/disable all third-party repositories.
Restore to open-source drivers:
- Also in Software & Updates utility, Additional Drivers tab, switch to the open-source drivers if proprietary drivers are in use. (Need restore after applied changes)
- And it's better to choose download from 'Main Server' in Software & Updates utility.
Make your system up-to-date by running command in terminal:
sudo apt update && sudo apt full-upgradeAfter all, launch Update Manager via the command below and it will prompt that Ubuntu 17.04 is available after checking for updates:
Source(s):
http://ubuntuhandbook.org/index.php/2017/04/upgrade-to-ubuntu-17-04-from-ubuntu-16-10/
http://www.omgubuntu.co.uk/2016/10/how-to-upgrade-to-ubuntu-16-10
http://ubuntuhandbook.org/index.php/2016/10/upgrade-ubuntu-16-10-from-ubuntu-16-04/
https://wiki.ubuntu.com/TrustyTahr/ReleaseNotes#Upgrading_from_Ubuntu_12.04_LTS_or_Ubuntu_13.10
- 37,534
