A laptop with broken screen that I access via SSH. The sudo apt-get autoremove command gives me the following errors
cp: error writing ‘/tmp/mkinitramfs_zN6ZvT//lib/x86_64-linux-gnu/libpthread.so.0’: No space left on device
cp: failed to extend ‘/tmp/mkinitramfs_zN6ZvT//lib/x86_64-linux-gnu/libpthread.so.0’: No space left on device
cp: error writing ‘/tmp/mkinitramfs_zN6ZvT//sbin/modprobe’: No space left on device
cp: failed to extend ‘/tmp/mkinitramfs_zN6ZvT//sbin/modprobe’: No space left on device
cp: error writing ‘/tmp/mkinitramfs_zN6ZvT//sbin/rmmod’: No space left on device
cp: failed to extend ‘/tmp/mkinitramfs_zN6ZvT//sbin/rmmod’: No space left on device
I get similar errors from various other commands but gparted tells me there is more than 20GB space left on the (single) partition on the laptop. Here is the output of df
$ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 502644 484 502160 1% /dev
tmpfs 505433 503 504930 1% /run
/dev/sda1 7331840 214087 7117753 3% /
none 505433 2 505431 1% /sys/fs/cgroup
none 505433 3 505430 1% /run/lock
none 505433 4 505429 1% /run/shm
none 505433 16 505417 1% /run/user
overflow 505433 401 505032 1% /tmp
And:
$ df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 2010576 12 2010564 1% /dev
tmpfs 404348 1284 403064 1% /run
/dev/sda1 115247656 83994028 25809372 77% /
none 4 0 4 0% /sys/fs/cgroup
none 5120 0 5120 0% /run/lock
none 2021732 204 2021528 1% /run/shm
none 102400 16 102384 1% /run/user
overflow 1024 1024 0 100% /tmp
Error started after I ran sudo apt-get upgrade.
