-3
I want to make an alias for sudo i.e.
alias now="echo [password] | sudo -S"
but it doesn't seem to work...
I was thinking that something like the following would work
alias now="echo [password] | sudo -S ${command_line_parameter}"
but I don't know what "${command_line_parameter}" would be... Any ideas?
This post is only aimed to answer the how to of your question, however as others suggest it, you should consider implementing your desired rules in /etc/sudoers file, something like:
james  ALL=(ALL:ALL) NOPASSWD: /bin/ls
You can't pass an argument to an alias in a way you are doing it, you can use "functions" instead:
now(){ echo $1 | sudo -S $@ }
and use it like:
now password
If you want to hardcode your password:
now(){ echo your-password | sudo -S $@ }
Which non of them are a good thing to do at all, it's like giving your password away.
Ravexina
  • 57,256
