13
I do not know how it comes, but my calendar(upper right corner) is in Polish. How to change this to English?
If everything except date is in English, then there is a high chance that the value of LC_TIME is something wrong, use localectl command to change it to your desired locale:
sudo localectl set-locale LC_TIME=en_US.utf8
or en_GB.utf8 for UK.
You can also place LC_TIME=en_US.utf8 at this file /etc/default/locale manually if you wish.
Ravexina
  • 57,256
data utility uses variable LC_TIME to know what language of days to use. If you want to know if this is really the issue, try:
echo $LC_TIME
then if you dont want to mess up anything, but still have different language in your script just change it in your script like
LC_TIME=en_US.utf8
The default locale file location here: /etc/default
First install: nautilus-admin then logOut and logIn.
Then go to /etc/default.
Right click on locale and Edit As Administrator.
Edit locale file like this and save:
#  File generated by update-locale
LANG="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
Done. Now log-out and log-in.
Eric Abraham
  • 71
Select the system settings "window". Click on Language Support. In the Regional Format tab set the preferred language. I had same problem when I first set clock wound up in Spanish. You will need to restart after change to take affect.
jim
