There is no postgresql option in the autorun menu, but it starts when the system starts. Searches have failed. Can you help?
Asked
Active
Viewed 324 times
postgresql starts as a systemd service. To stop autorun of it, simply execute this command in terminal
sudo systemctl disable postgresql
This should disable autorun of postgresql upon boot. If you want to re-enable it, use
sudo systemctl enable postgresql
command.
Anwar
- 77,855
Since it is a service not a autorun program for your user you have to disable it via systemctl.
sudo systemctl disable postgresql.service
Ziazis
- 2,184
Use sudo update-rc.d postgresql disable command to remove from autorun.
David Foerster
- 36,890
- 56
- 97
- 151
