Does HD 6450 work ok with Ubuntu 11.10? I have desktop computer and my screen is connected with DVI. I want to know should it work ok with Ubuntu and proprietary drivers. And my computer has an AMD APU Processor, which has GPU + CPU in one. But can i be sure it uses the HD 6450 card, not the integrated GPU from CPU.
ATi have official Linux drivers for it so I imagine it works fine
Source: http://support.amd.com/us/gpudownload/Pages/index.aspx
- 21
I can confirm the Biostar Radeon HD6450 pcie (DVI+VGA+HDMI) works fine with Ubuntu 12.04; u get OpenGL accel along with desktop effects (compiz) and tested with UrbanTerror to verify proper 3D gaming.Although I couldnt make the card works with an HDMI tv, DVI output is ok.
- 11
- 1
All radeon HD cards "work" with Ubuntu in the sense that you can use them to display graphics using at least one driver (vesa would be the worst case scenario), but maybe you wanted to ask if 3d acceleration will be supported?
As for knowing which GPU is used, I would first visit the BIOS as there may well be some options in there that are relevant to this question. Second, you can run lspci and lspci -v from the command line to see what PCI(e) devices are seen by the operating system.
Finally, I would look at the X11 server log file (/var/log/Xorg.0.log generally) to see what devices the server found and initialized.
- 377
