So I tried dual booting my desktop today which has windows 7 installed on hard disk one which only contains the windows partition. I tried to install Ubuntu 17.04 on hard disk 2, which is on a 1 tb partition (sdb4). I tried boot repair and it does not seem to have done anything of use. Now when I try to load disk 1 it gives me a error with grub rescue and when I try and load disk2 it goes in a loop where it just keeps rebooting until I stop it. I have no clue where to begin to fix this. Any help at all fixing this would be greatly appreciated. Thanks! Disk 2: Partition 1: 135 mb (Microsoft reserved) Partition 2: 3TB (Basic data partition) Partition 3: 1 mb (Bios Boot) Partition 4: 1 TB (Linux Filesystem)
Asked
Active
Viewed 143 times
You can fix your grub using your live CD.
- Boot with your Ubuntu live CD again and enter a live session.
- Press Ctrl + Alt + T to open the Terminal.
- Type
sudo update-gruband wait. - Reboot to see if your grub got fixed. If not, try typing
sudo grub-installto reinstall the grub.
Edit:
Since you can't update your grub using update-grub, I am giving you a solution (refer to Cannot update grub with parameters on live USB):
After booting the live CD, Mount your Ubuntu partition to /mnt with:
sudo mount /dev/sd*# /mnt
where /dev/sd*# is updated to your Ubuntu partition.
If you have a separate /boot partition, mount it in /mnt/boot as well:
sudo mount /dev/sd*# /mnt/boot
where /dev/sd*# is updated to your /boot partition.
Update grub with the correct root and target:
sudo grub-install --root-directory=/mnt /dev/sdX
where /dev/sdX is the disk(not the partition) where grub is installed.
Cynplytholowazy
- 1,339
