I wanted to try Kontact, but that automatically installed another bunch of packages. After deciding that I didn't really like Kontact, I removed it with
sudo apt-get remove kontact
but that doesn't remove all the other programs which were installed with kontact, like korganizer, knotes etc...
How do I find which packages were automatically installed in the process of installing a certain application (in this case kontact) so that I can remove them.
LinG
  • 225
You should use autoremove sub command:
sudo apt autoremove kontact
From man apt:
autoremove is used to remove packages that were automatically installed to satisfy dependencies for other packages and are now no longer needed as dependencies changed or the package(s) needing them were removed in the meantime.
You can also use --purge to remove config files too:
sudo apt autoremove kontact --purge
If autoremove does to work for you so you should do it manually, run something like:
grep kontact -A10 /var/log/apt/history.log
to see which packages are installed by kontact then remove them manually.
Ravexina
  • 57,256
