I have added cronjob -e with below-
* * * * * /usr/bin/python3  /home/user/test.py
But the cronjob is failing everytime. I can test the script while running normally and its working fine.
The cron is required to run every minute and have tested with echo and redirecting output to a file and that works perfectly fine. After trying with both user & root in separate instance it didn't work. I have check the syslog and here is what i can see-
May 20 06:30:01 ubuntu CRON[2145]: (user) CMD (/usr/bin/python3  /home/user/test.py)
May 20 06:30:01 ubuntu CRON[2144]: (CRON) info (No MTA installed, discarding output)
May 20 06:31:01 ubuntu CRON[2148]: (user) CMD (/usr/bin/python3  /home/user/test.py)
May 20 06:31:02 ubuntu CRON[2147]: (CRON) info (No MTA installed, discarding output)
May 20 06:31:29 ubuntu crontab[2150]: (user) BEGIN EDIT (user)
May 20 06:31:37 ubuntu crontab[2150]: (user) REPLACE (user)
May 20 06:31:37 ubuntu crontab[2150]: (user) END EDIT (user)
May 20 06:31:46 ubuntu crontab[2162]: (root) BEGIN EDIT (root)
May 20 06:31:54 ubuntu crontab[2162]: (root) REPLACE (root)
May 20 06:31:54 ubuntu crontab[2162]: (root) END EDIT (root)
May 20 06:32:01 ubuntu cron[862]: (root) RELOAD (crontabs/root)
May 20 06:32:01 ubuntu cron[862]: (user) RELOAD (crontabs/user)
May 20 06:32:01 ubuntu CRON[2177]: (user) CMD (/usr/bin/python3  /home/user/test.py)
May 20 06:32:01 ubuntu CRON[2178]: (root) CMD (/usr/bin/python3  /home/user/test.py)
May 20 06:32:01 ubuntu CRON[2175]: (CRON) info (No MTA installed, discarding output)
May 20 06:32:01 ubuntu CRON[2176]: (CRON) info (No MTA installed, discarding output)
May 20 06:33:01 ubuntu CRON[2183]: (user) CMD (/usr/bin/python3  /home/user/test.py)
May 20 06:33:01 ubuntu CRON[2184]: (root) CMD (/usr/bin/python3  /home/user/test.py)
May 20 06:33:01 ubuntu CRON[2182]: (CRON) info (No MTA installed, discarding output)
May 20 06:33:01 ubuntu CRON[2181]: (CRON) info (No MTA installed, discarding output)
Can't able to figure out what this MTA means here. Read is some forum mailx installation is required as this is a bug. there is no direct mailx installation support on 16.04 may be older version supported it.
Your help is highly appreciated here. Please help me with your inputs.
Thanks,
MTA is mail transfer agent. When you enter
crontab -e
add a line
MAILTO=""
I am not sure it helps.
Anyway, any output to standard output is sent by e-mail if you run it in cron.
nobody
  • 4,412
Thanks All,
I fixed it by installing
sudo apt-get install mailutils
I see the desired logs that the mails are getting generated by logs-
May 20 08:02:01 ubuntu CRON[4687]: (user) CMD (/home/path/test.py) May 20 08:02:01 ubuntu postfix/pickup[4397]: CB907603B5: uid=1000 from= May 20 08:02:01 ubuntu postfix/cleanup[4477]: CB907603B5: message-id=<20170520150201.CB907603B5@ubuntu>
But i dont see my script running - but my path is correct and there isn't any issue while just typing the whole the script is running fine.
