31
So I use Git mostly for development purposes, but I just realized that I could use it for storing versions of the settings files I have on my Ubuntu installation.
My proposed setup is:
  • git init a repo at /
  • Add a .gitignore at / that ignores any files except specific settings I want to track.
    For example, the .gitignore could contain (source):
    ## Ignore everything...
    ## Except...
    !/etc/default/tlp
    !/etc/crontab
  • Whenever I change these low-level settings, I can track them.
Is there anything that could go wrong with this setup? Does the kernel always need / to only have certain folders? Will it mess up the functioning of any applications?
Abhishek Divekar
  • 724
  • 17
5 Answers5
43
The answer to both of your questions is no, you can create any directory you want in the /. the only thing that could happen is some permission issues with some spacial paths I guess.
However it's better to store the .git directory somewhere else, something look like:
git --git-dir=/home/user/backup-root --work-tree=/
Read here.
Ravexina
  • 57,256
19
Actually, you probably want to version control configuration files in /etc/ (you don't care about the entries of the root directory /, notably directories like proc or usr or bin in /) so you may want to install the etckeeper package
And you could also version control some selected subdirectories (like /usr/share/applications/ that you mentioned).
However, don't mess with the Ubuntu package management system. Perhaps you mostly should backup the current list of installed packages.
Having a git repo in / works fine, except that it does make it hard to notice when you have a lower level git repo with problems as it will answer for all of them.
Note: It is less work and probably more useful to use 'debsums'
sudo apt-get install debsums
Which will allow you to quickly detect (most) changes in binaries or in configuration files.
As an example from the installed packages here are the ones that differ from the upstream packages.
$ sudo debsums -c
/boot/vmlinuz-4.10.0-19-generic
And you can get a list of changed configuration files with:
$ sudo debsums -ec
debsums: missing file /etc/default/chromium-browser (from chromium-browser package)
 /etc/libvirt/libvirt.conf
 <snip>
Note how the chromium-browser is improperly packaged and and has a file listed in the the package file list that doesn't exist.
/var/lib/dpkg/info/chromium-browser.list
This uses the dpkg data and avoids a large /.git directory and workflow.
gdahlm
  • 469
So I've been exploring the other answers and I've found a procedure which works for me:
  • Make a .gitignore at /. This was much more complicated than I thought it would be, because of the way Git handles whitelisting files in subfolders. I used this and this link to help me.
    ## Source: https://stackoverflow.com/a/29932318/4900327
    ## Comments are on new lines because trailing whitespace matters in Git (stackoverflow.com/a/8865858/4900327)
    # Blacklist all files, folders and subfolders in the same directory as the .gitignore file.
    # Do not blacklist the .gitignore file.
    !.gitignore
    # Now whitelist certain files.
    # For files in subfolders, some hoops must be jumped through (stackoverflow.com/a/16318111/4900327):
    ## Whitelisting files in /etc/ folder:
    # Whitelist the /etc/ folder (the git repo folder is whitelisted always)
    !/etc/
    # Blacklist all files in /etc/ folder.
    /etc/*
    # Whitelist specific file(s) in /etc/ folder.
    !/etc/crontab
    ## Whitelisting files in /etc/default/ folder:
    # /etc/ is already whitelisted, and its contents blacklisted.
    # Whitelist /etc/default/ folder.
    !/etc/default/
    # Blacklist all files in /etc/default/ folder.
    /etc/default/*
    # Whitelist specific file(s) in /etc/default/ folder.
    !/etc/default/tlp
    ## Whitelisting files in /home/USERNAME/ folder:
    # Whitelist /home/ folder.
    !/home/
    # Blacklist all files in /home/ folder.
    /home/*
    # Whitelist /home/USERNAME/ folder.
    !/home/USERNAME/
    # Blacklist all files in /home/USERNAME/ folder.
    /home/USERNAME/*
    # Whitelist specific file(s) in /home/USERNAME/ folder
    !/home/USERNAME/.bash_profile
    !/home/USERNAME/.bashrc
  • Go to / and run git init . So far, I have been unable to store the .git/ folder in another directory using the link mentioned by @Ravexina.
  • Run git add . and git status. You should get a listing of all the settings files Git is tracking.
    If you used the above `.gitignore`, it should track `/etc/crontab`, `/etc/default/tlp`, `/home/USERNAME/.bash_profile`, and `/home/USERNAME/.bashrc`.
  • Commit with git commit -m "Initial settings files".
  • You can track changes with git log -p -- path/to/fileor gitk path/to/file. More discussion on this here.
Abhishek Divekar
  • 724
  • 17
If you are going to store sensitive stuff (like /etc/shadow) in the git repo, you should make sure it's not readable by all users, since by default the objects will have the permission 444 and directories will have the permission 0755. You can change the permission of .git to 700 or put it in /root
Another problem is that git doesn't store file permissions like the file system, and it doesn't store extended attributes. For files, git only stores whether they are executable. So if you want to restore a deleted file, its owner and group will be root (if you do it as root), and its permission will be 644 or 755. It may be problematic for services' configuration files whose owner is not root.
