So my Linux experience began a week ago. I thought that Ubuntu is a great project so switched to it instead of Windows as I saw that just replacing it was easier and less tedious. So I made the backup image plus the Windows Recovery on a USB stick (I tested if it worked or not before installing Ubuntu and it worked) then I decided that it was time that I switch back to Windows. The USB stick is on the first slot of boot order in the BIOS but it still boots Ubuntu instead of the Windows recovery USB. So I tried to uninstall grub and now I'm stuck in grub rescue and the usb stick still doesn't boot even though it is supposed to boot first.
Asked
Active
Viewed 433 times
Are you trying to reinstall windows or run it live off the usb? A couple options for either: It is not automatically booting because of a misconfiguration in you bios. I would first repair grub, then launch into bios and manually select the usb to boot from. (Not just changing boot order but 'boot menu' itself.)
Research BIOS settings for you make and model of computer and specifically pay attention to mentions of UEFI and secure boot, as these are likely culprits
Joe
- 172
