I installed kdeconnect and indicator-kdeconnect as explained at OMG! Ubuntu! and github:
sudo add-apt-repository ppa:varlesh-l/indicator-kdeconnect
sudo apt update
sudo apt install kdeconnect indicator-kdeconnect
Everything seems to work properly except the Browse device functionality. If I click on the indicator and then on Browse device, nautilus pops-up however the directory ($HOME/.config/kdeconnect/[DEVICEID]/kdeconnect_sftp/[DEVICEID]) is empty.
Do you have any suggestion on how to proceed from here?
Thanks in advance.
Environment
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
Package Version
dbus
$ apt show dbus
Version: 1.10.6-1ubuntu3.3
kdeconnect
$ apt show kdeconnect
Version: 1.0.3ubuntu16.04
$ apt show indicator-kdeconnect
Version: 0.6ubuntu16.04.1
Syslog
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Mount device: "google"
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Created mounter
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Unmount QObject(0x0)
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Starting process: "sshfs kdeconnect@192.168.1.3:/ /home/ncrfgs/.config/kdeconnect/28cebede2fc57937/kdeconnect_sftp/28cebede2fc57937 -p 1739 -f -F /dev/null -o IdentityFile=/home/ncrfgs/.config/kdeconnect/privateKey.pem -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null -o HostKeyAlgorithms=ssh-dss -o password_stdin"
org.kde.kdeconnect[12766]: QDBusAbstractAdaptor: Cannot relay signal SftpPlugin::packageReceived(NetworkPackage): Unregistered input type in parameter list: NetworkPackage
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Process started
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: "google" "Remote filesystem mounted at /home/[USER]/.config/kdeconnect/[DEVICEID]/kdeconnect_sftp/[DEVICEID]"
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: stdout: "fuse: bad mount point `/home/[USER]/.config/kdeconnect/[DEVICEID]/kdeconnect_sftp/[DEVICEID]': Transport endpoint is not connected\n"
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Process finished (exit code: 1 )
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: "google" Remote filesystem unmounted
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Unmount KProcess(0x1d92650)
org.kde.kdeconnect[12766]: kdeconnect.plugin.sftp: Destroy mounter
