Problem description:
My intention is to enable PHP5 on Xenial 16.04 for an Apache2-related project
I have compiled PHP v5.6 from official source and am currently trying to install package libapache2-mod-php5.6 using https://launchpad.net/ubuntu/xenial/amd64/libapache2-mod-php5.6/5.6.18+dfsg-4ubuntu1
After attempting to resolve dependencies, I end up with php5.6-common from https://launchpad.net/ubuntu/xenial/amd64/php5.6-common/5.6.18+dfsg-4ubuntu1 depending on php-common, however, after installing said php-common via apt, I keep getting following message:
      php5.6-common : Depends: php-common (>= 18~) but it is not going to be installed
Do I also need some outdated version of php-common?
Should I also build libapache2-mod-php5.6 from source (and if so, are there any code packages suited to compile properly on Xenial)?
NOTE: I am NOT supposed to use Ondrej's ppa due to company policy
karel
  • 122,292
  • 133
  • 301
  • 332
B.S.
This is similar to your problem. So as written there, you could give
sudo apt-get -f install
a try which is supposed to search and install unmet dependencies.
Matthieu
  • 506
ADDB
  • 1,608
