I was unable to install subversion on Ubuntu 14.04. I am getting the error message below:
$ sudo apt-get install subversion
Reading package lists... Done
Building dependency tree
 subversion : Depends: libsvn1 (= 1.8.8-1ubuntu3.2) but it is not going to be installed
              Depends: libapr1 (>= 1.4.8-2~) but it is not installable
              Depends: libaprutil1 (>= 1.2.7+dfsg) but it is not installable
Please could be the problem.
One possible cause is that you don't have the latest versions of some packages. You should try updating first by running this:
sudo apt-get update
sudo apt-get upgrade
Kalle Elmér
  • 9,216
