I have installed Ubuntu 16.04 with Windows 10. No matter what I do, it always boots up Windows first. I have tried four ways:
  • Changed boot order using sudo efibootmgr -o command on Ubuntu.
  • Used bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi to change the windows boot file.
  • Used EasyUEFI on windows to change the File Path of the windows boot manager to both \EFI\ubuntu\shimx64.efi and \EFI\ubuntu\grubx64.efi.
  • Again used EasyUEFI to change the order of different boot profiles.
Disappointingly, every boot process starts directly booting the windows. On checking the boot order and its settings I find that there are two windows boot profiles. One of these two always stay at the top, and is uneditable by every means that I tried.
Zanna
  • 72,312
Sanjay
  • 163
I prefer a GUI for stuff I barely understand. So, I use grub-customizer for this exact reason. It is confirmed working for me on 16.04,02 and 16.10. It allows you to set the boot order and default boots from a convenient GUI.
If you want to try it out, you can add the ppa which is ppa:danielrichter2007/grub-customizer
Then;
$sudo apt-get update
and finally
$ sudo apt-get grub-customizer
It should show up in your tools menu somewhere.
Orian
  • 1,200
  • 14
  • 19
