I have a Samba4 domain controller and have added a Ubuntu 16.04 member server to the domain. I'm using samba+winbind for this and everything appears to work. The idmap backend is setup using "ad". Here is the smb.conf for reference.
[global]
        workgroup = name
        realm = NAME.DOMAIN.COM
        netbios name = app02
        security = ADS
        log file = /var/log/samba/%m.log
        log level = 1
        # Default idmap config for local BUILTIN accounts and groups
        idmap config * : backend = tdb
        idmap config * : range = 3000-7999
        # idmap config for the NAME domain
        idmap config NAME:backend = ad
        idmap config NAME:schema_mode = rfc2307
        idmap config NAME:range = 10000-999999
        # Template settings for login shell and home directory
        winbind nss info = template
        template shell = /bin/bash
        template homedir = /home/%U
        winbind use default domain = yes
The issue I'm having is related to authenticating (SSH) when I do NOT set winbind use default domain = yes in smb.conf.
When you set this equal to yes the various commands like wbinfo -u, wbinfo -g, getent passwd UserName will return an account WITHOUT the domain name. If you don't set this you get results like Domain\UserName and Domain\Domain Users. The reason you might not want to set this is because it would limit your logins to a single domain.
However, when I remove this setting from smb.conf I can no longer login. I suspect it is a formatting issue when trying to provide domain\username at the SSH login. I've tried domain\username, domain+username, username, and username@domain. All have failed.
Does anyone know how to get SSH logins working for these AD users when winbind use default domain is not set?
JayG30
  • 61
Figured out the problem
I was removing the winbind use default domain setting in smb.conf and then running sudo smbcontrol all reload-config. I figured this would be enough to set everything straight, but it wasn't.
For whatever reason winbind wasn't updating. I need to stop the service, clear the cache, and restart.
service winbind stop
net cache flush
service winbind start
Strange enough, once I did this the problem hasn't resurfaced. Now I can change the winbind use default domain setting and/or the winbind separator, run sudo smbcontrol all reload-config, and the login credentials change and work.
JayG30
  • 61
