I'm currently using a LG laptop with Nvidia Cuda GeForce GT 335M.
I have difficulty adjusting the screen brightness using FN+Arrow Up/Arrow Down. The brightness indicator will appear and the bar will not decrease beyond the first jump. Subsequently, if I depress the button, the indicator bar will randomly appear to be dim and bright, with no actual difference to the screen brightness.
I have tried to adjust the brightness through System Settings>Screen. Although the bar can be dragged up and down, there seems to be no actual difference in the brightness.
Furthermore, after installing Ubuntu 11.10, I have difficulty adjusting the brightness in Windows 7 as well. The function button does not respond at all, and adjusting it through the Control Panel does not seems to have any actual difference.
What could be the problem?
I have tried to edit the /etc/X11/xorg.conf, and add the line Option "RegistryDwords" "EnableBrightnessControl=1", but it is not working for me.
Jorge Castro
  • 73,717
Try this: https://askubuntu.com/a/120796/54126 Confirmed working solution on clean Ubuntu 12.04 beta2 with 3.2.0-22 kernel with latest nvidia drivers. FN keys work, no need to make changes in grub or Xorg.conf
If the button is not working either in ubuntu or windows, then the problem may be coming from the button itself rather than ubuntu. I would have that button checked, maybe it is buged or some connection to the motherboard went MIA.
Jester
  • 162
try this on your terminal.
sudo setpci -s 00:02.0 F4.B=50
dsaint
  • 774
