Since nobody could tell me how to do exactly what I wanted, here's the solution I came up with:
Disabling the touchpad/mouse
$ xinput --list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ FSPPS/2 Sentelic FingerSensingPad id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Sleep Button id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ USB2.0 UVC PC Camera id=10 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=11 [slave keyboard (3)]
↳ MSI Laptop hotkeys id=13 [slave keyboard (3)]
As we can see, my touchpad is the one with id=12. To disable it, I need to run:
$ xinput set-int-prop 12 "Device Enabled" 8 0
and to enable it again:
$ xinput set-int-prop 12 "Device Enabled" 8 1
Getting the lid state
First of all, I can get the state of the lid on my system from this file:
$ cat /proc/acpi/button/lid/LID0/state
state: open
When I close the lid, the state becomes closed.
Now to get the state as a variable, I can check the exit status of a nifty grep command:
$ grep -q closed /proc/acpi/button/lid/*/state
$ echo $?
So to enable or disable the touchpad depending on the lid state, all I need to do is:
$ xinput set-int-prop 12 "Device Enabled" 8 $?
Hooking the ACPI lid event
To execute the above commands every time the lid closes or opens, I created the file /etc/acpi/local/lid.sh.post with the following content:
export XAUTHORITY=`ls -1 /home/*/.Xauthority | head -n 1`
export DISPLAY=":`ls -1 /tmp/.X11-unix/ | sed -e s/^X//g | head -n 1`"
XAUHTORITY and DISPLAY need to be set in order to allow root (who runs the acpid process) to access the user's X session.
